Clicks and creaks can be hard to pin down.
This one should be obvious though.
I've got this shss-shss-shss noise. About three per pedal revolution.
It sounds exactly like a mudguard rubbing on a tyre, and of similar volume (it's not like a barely detectable noise)
And I do have mudguards.
And tyres.
But I've checked several times and there is clear space all around the 'guards and stays. I've spun the wheels and I can't see any or hear anything rubbing.
When I say several times I mean about 20 times.
Nothing obviously fouling the hub bodies.
Chainstays are wide on this bike. Miles away from the tyre.
It isn't the front brake rubbing because today I unhooked the bendy doodad on the V-brake from the thingy on the brake arm so the brake arms were all floppy and rode the bike like that (my first experience of brakeless fixed btw).
shss-shss-shss-shss
It isn't the rear brake rubbing because there isn't one.
Front hub is an ageing dynohub. Figured it might be that, outside chance. Put in another -known good- wheel.
And left the brake unhooked for good measure.
shss-shss-shss-shss
I put the bike upside down and spun the pedals. No similar noise from the rear wheel or hub. Chainring, cog and chain were all replaced at the same time earlier this year but I have had the rear wheel off a couple of times to change tubes- didn't notice whether the noise started after this as I haven't ridden it much recently.
I don't get it.
And tyres.
shss-shss-shss-shss
shss-shss-shss-shss
I don't get it.
