DCBassman
- The lumpy far South West
Bah, you can't go too low on gears. My lowest on the Trek mtb is 28/36 on 26" wheels, 30/36 on the Scott on 700c wheels. It's just about low enough...
That's the kind of thing that I do. If I am avoiding the steep local hills I have to stick to the undulating valley roads or the long but pretty gentle Cragg Vale climb so I usually use my singlespeed bike to make those rides a bit harder. If I want a hard ride there are plenty of 10-20% climbs round here but I want my low gears for those! I can only do the Cragg Vale loop clockwise on singlespeed. If I want to do it anticlockwise I have to use the geared bike for the much harder climb from Littleborough...Hillier route one ride, flatter route next ride.
So what do your flat rides look like? So far we've got very hilly and hilly.That's the kind of thing that I do. If I am avoiding the steep local hills I have to stick to the undulating valley roads or the long but pretty gentle Cragg Vale climb so I usually use my singlespeed bike to make those rides a bit harder. If I want a hard ride there are plenty of 10-20% climbs round here but I want my low gears for those! I can only do the Cragg Vale loop clockwise on singlespeed. If I want to do it anticlockwise I have to use the geared bike for the much harder climb from Littleborough...
Wind conditions play a big part too. I often get a tailwind on those 2 drags up towards Burnley, but a cross-headwind on the top half of the big climb above Cragg Vale.
This is the north! Many rides would be at least 3000+ and often 4-5000. Less than 2000 feet would be flat. Rode to Cheshire yesterday, now that is flat.So what do your flat rides look like? So far we've got very hilly and hilly.![]()
but it's reasonable to assume that additional strength is desireable for sprinting and particularly tough climbs,
The key is at what point do you switch from anaerobic to aerobic effort. Anaerobic effort is largely limited by maximum strength. Aerobic effort is limited by your CV system. On an aerobic climb the force applied through the pedals is small so being "stronger" is of little benefitThanks guys!
Lots of good info and I won't quote all the relevant posts as I'll be here all day.. suffice to say I'm impressed by what some of you are managing / subjecting yourselves to on single speeds!
To be clear I'm not questioning the legitimacy / usefulness of low gearing on hills and all things being equal would always prefer to have that versatile low range available to me. Yesterday's ride was a good case in point - felt a bit rough so low intensity was the name of the game and the low gear really helped keep the leg-exertion in check on the hills. I have dodgy knees too so limiting the force they transmit is also welcome sometimes.
I get the point about producing the same power regardless of how it's achieved, but each end of the spectrum (high load, low speed, low load high speed) have different demands on the body so promote development in different ways. While everyone likes a slightly different cadence and their default crankspeed should be whatever they find most comfortable, my point is that with lower gearing available we're missing the high-load workouts that would be required with higher gearing and thus might be missing out of strength development as a result; perhaps skewing the modern cyclist's fitness more in the direction of endurance over strength compared to what might have been the case 30yrs ago...?
I guess it depends what you're aiming for (if indeed you're aiming for anything at all beyond the pleasure of just getting out) but it's reasonable to assume that additional strength is desireable for sprinting and particularly tough climbs, so some opportunity to develop strength during each ride would be welcome.. also a bit of strength training might provide another area of development for those of us who've reached the limit of our endurance (personally I find after 55-60 miles I've had enough - bored of riding and aching in non-muscular places).
Thanks to the versatility of modern drivetrains at least we have the option of pushing ourselves harder by consciously selecting a tougher gear up the hills![]()
Yep I've always found the harder I try the worse I get whereas if I just relax I can go much further and at a faster speed.This is the north! Many rides would be at least 3000+ and often 4-5000. Less than 2000 feet would be flat. Rode to Cheshire yesterday, now that is flat.
As for cadence and strength for climbing. For me regardless of gearing it's just about selecting a comfortable gear, sit up, relax and set an appropriate pace**. For me this takes a lot of discipline as I'm often tempted to push for a good time and then it all falls apart.
Many of my PBs come on days when I don't attempt to ride a hill hard. Bizarre and proves the point for me.
** I was going to say "spin up" but that implies a high cadence. I feel it's much more important to simply relax and let the legs work as they wish. Sometimes I find it harder (more uncomfortable) to spin a low gear than ride a higher one at a lower cadence.
Out of very idle interest would that be from Harrowbeer Lane up Grange Road to Tavistock Road? I don't know it but had a look on RWGPS, looks very tasty!I will say that one of my 'nemesis' climbs, the short but steep ramp up to Leg O'Mutton on NCN27 near Yelverton, I've only climbed it once in one go, on the Trek, at 28/34 gearing. Never managed it on the Scott, despite it being 10lb lighter! So maybe @nagden has a point here.
