There shouldn't be any noise -- as you say, it is annoying.
Assuming these are Avid mechanicals, then I suggest re-setting them up -- you can get instructions from the Avid web site. Basically, you (1) slacken the bolts that mount the caliper housing to the frame/fork, (2) use the red wheels on the caliper housing to get the calipers to clamp the rotor tight (set the rotor one-third on the wheel side, two-thirds on the outer side), (3) tighten the mounting bolts, and (4) slacken off the red wheels until the wheel runs free and silent. It is a clever system and easy to do.
If you can't get it to run free without putting too much play in the calipers, then you have a bent rotor.
But are these brakes Avids?
Tom
Tom
