Willow said:
yes but I can hear it very annoying and closer inspection shows it rubs against the brake the disc looks slightly bent. I am sure it didn't do that on the first couple of outings - I have chucked a couple of buckets of water of area to make sure it is clean.
if the disc's slightly bent, then get a large adjustable spanner, and find the point where it is most catching on the pad, and obviously also note which side it is catching on, thus which way it is bent - then tighten the adjustable spanner on it and pull (or push) the end of it till there's some resistance, hold it for about 5 seconds then release. Test. Do it in small increments, gently at first, then increase the force if it doesn't appear to be making any difference, but it will do if you do it right. Don't bend it enough for it to visibly bend, but possibly so that the outer circumference of the disc moves
roughly say 10-20mm laterally. Keep doing it and test by spinning it after each go, and do it in as many different places as necessary.
If it's *visibly* bent though i'd consider getting a new rotor.
