Panter
Just call me Chris...
- Sittingbourne, Kent
or could it be welded? (aluminium SCR3.0)
Thanks for the replies all, I feared as much![]()
Tempting as a new carbon frame isunfortunately funds are extremely tight at the moment. However, rumours on the internet suggest that Giants frame warranty may be 5 Years? I'm investigating further...
Angelfishsolo, I've no idea how it happened, I just noticed it. I assume it's just a stress fracture from bumping over Kent's dodgy road surfaces for the last 4 Years.
How much seatpost do you have inside the frame? Min insertion marked on seatpost doesnt equal minimum insertion required by the frame. I'd double check that you have enough seatpost in the frame, if not, the warranty is useless.
The seatpost min insertion, as a general rule should be at least below the top tubes bottom surface, but this varies from frame to frame.
Could be just an unfortunate event, but it could be caused by seat post not being inserted far enough.
