I know another "clicking noise" thread
bianchi1
malverns
This might seem a long shot but I once had a 'click while peddling' that was caused by an over tight bottle cage bolt. Drove me crazy for months. When I loosened it there was a loud click..then problem solved.
Worth a shot.
ianrauk
Tattooed Beat Messiah
Rides Ti2
Nope just loose.
However although that was obviously a problem, fixing it hasn't fixed the clicking. Running out of ideas now.
What are pinch bolts? The ones I replaced are the ones that bind the chain rings to the crankarm
Try a spacer...
martint235
martint235
Dog on a bike
Welling
Try a spacer...
A spacer wouldn't explain a problem that hasn't been there for years and is now suddenly there. But thanks for your help!! :tongue:
Right I've now cleaned the front stem plate. I also managed to get a few more turns out of a couple of the chainring bolts (I'm always scared of breaking them!!!). Unfortunately I'm now at the stage where I daren't take it out as if it still clicks I'll be gutted. I'll now wait till Monday morning. Anyway work beckons!!
Nope just loose.
I mean the bolts that hold the crankarm onto the axle. See the first photo of this explanation. Although as I said above, it's only applicable if you have Hollowtech II.
Often have this problem through our workshop! People will swear it is bb/crank/pedal problem. More often than not it is cured by removing the front plate stem bolts. cleaning the crap out, grease them, refit and torque up. I know it sounds unlikely and many customers don't believe me but when you are rding you are actually pulling on the bars a lot.
The important bit here is the grease on the bolts as it's them wot cause the creak/click noise. Anyway lets hope you've got it this time....:popcorn:
ianrauk
Rides Ti2
Right. New bike time.
Anyone want to buy a Giant SCR A1 in XL with a clicking noise on the drivetrain? £200 ono
Fit a spacer...
martint235
martint235
Dog on a bike
Welling
[QUOTE 2559827, member: 259"]This may sound like a silly question, but have you tried wearing a different pair of shoes?[/quote]
At the moment nothing is a silly question. No I haven't but I have ridden a different bike with the same shoes and no issue.
GrumpyGregry
Here for rides.
GT 85 or a teflon dry lube on the cleat mechanism make any difference?
Are the pedal threads greased and torqued?
martint235
martint235
Dog on a bike
Welling
Pedal threads were regreased after I'd tried different pedals on it :sad:
If I can be convinced the Merlin Single Malt will fit me, the Giant is being retired.
