fossyant said:What frame is it ?
Over The Hill said:No expert here but I have looked at the Felt range and they do two specific ranges in the road bikes (as well as lots of others) one lot is designed sold as a softer more comfortable setup and the other a more full on racer.
If you look at the two they really do not seem much different to look at but i guess the setup is different. If you can pin down the difference then you can see if it is really the frame that is the problem.
It would be tragic to get a new bike and find you have the same problem. Have you tried borrowing another bike to try out?
