mrbikerboy73
- Worthing, UK
For those who've never seen this, it's worth a read...
http://www.jimlangley.net/wrench/keepitquiet.html
For a few days I had a terrible creaking coming from my Cannondale synapse Alloy 2014.
Having convinced myself it was my seat post, I took it out and regressed it.
The creaking continued.
I decided it was coming from the handlebar area. So I watched the GCN video in headset servicing, and dropped out my forks. Would you Adam & Eve it, the headset bearings were about as dry as Ghandi's flip flop.
With the bearings having no markings, I got out my steel ruler and measured them. I ordered some new bearings of ebay size 1-1/8'' Size:30.2X41.8X6.5/45°X45° and replaced the dried up old ones.
Creaking resolved. Silence is golden.
So please remember to look after your balls. I will be servicing mine once a year from now on.
Taxi for Mr Mason ....My latest 'BB or possibly seatpost creak' turned out to be coming from the back wheel, as I hadn't got the QR as tight as it should have been after putting my new wheels on.
Finding out where these noises come from is often a mystery worthy of Scooby Doo or - wait for it - Jonathan 'Creek' ;-)
nope, its none of those.So, is it ...?
- The chainring bolts
- The stem
- The bars
- The chain
- The bottom bracket
- The cranks/crank bolts
- The pedals/cleats
- The seat post
- The saddle
- My knees/ankles
Blimey - for years I had wondered about the tiny mudguards that sometimes used to be fitted to old bikes. Clearly they wouldn't keep the rider dry OR riders behind. I hadn't thought about them keeping crud out of headsets (and brakes)!![]()
Yes, not pleasant! I have Crud Roadracers squeezed onto my Basso and ride that bike in bad weather. I have a set of mudguards to put on my CX bike but will have to bodge the stays slightly to fit round its disk rotors.I remember the little mudguards, I used to hate the cold and wet muddy streak up my back in bad weather, these days I'll use full mudguards only if I can.
Copper slip is better than grease at the seat tube / seat post interface (assumes both metal).decided it could be the seat post... Took it out, bit of grease and I couldn't believe the difference
That's what it was.... But it doesn't roll off the tongue so easily to say I copper slipped my seat post!Copper slip is better than grease at the seat tube / seat post interface (assumes both metal).
Vaseline (Petroleum Jelly) is even better (and it's clear)Copper slip is better than grease at the seat tube / seat post interface (assumes both metal).
Why?Vaseline (Petroleum Jelly) is even better
Why?
The concept of the copper (or nickel or whatever is chosen based on between what materials it will be used), like @Drago said is to provide a sacrificial anode. In other words, instead of the steel and aluminium post and frame to be anode and cathode, the copper becomes the anode [for both] and gets used up.
grease (of virtually any flavour) or vaseline will do as anti-seize. But given a 100 year supply of coppaslip is maybe a fiver I'd just get the right stuff.
use copper compound. The copper does two things, it provides a sacrificial anode to prevent galvanic corrosion and, copper has a low shear strength which helps other metals slide against each other under high pressure. Often, grease promotes galvanic corrosion and in some cases where the grease is massaged in the presence of water, it forms an emulsion that's deadly for some parts like seatposts and quill stems.
You can fix the annoying ticking noise form my CAAD5 for me now!
I have convinced myself that it is from the chainring bolts, but maybe it is from elsewhere. I certainly never considered looking at the headset.
its not the headset.
So, is it ...?
- The stem
- The bars
- The chain
- The pedals/cleats
- The seat post
- The saddle
- My knees/ankles
It's none of those either!For those who've never seen this, it's worth a read...
