Ajax Bay
- East Devon
Yes, the seal has not been pushed back in (should be deeper and pushed over the spacer on the axle (just push with a blunt headed 'thing')) after the OP had serviced the bearings.
You alluded to that suspicion two days ago!
Lock nut still seems too far out (beyond freehub edge) to me, mind. Should be about 3mm max.
I'd like to see the other end of the axle.
I assume this is an 11sp freehub and the 9sp cassette needs a 1.85mm spacer.
