cyberknight
- Land of confusion
I used to be the same , i just learned to to follow more experienced  riders line through a bend .
			This ^^ weight on outside pedal as you lean into the corner, you can even counter steer a little bit once you get into it. Also look a decent way ahead through the cornerLeft pedal up and push weight through right hand pedal - this will help.
I was going to suggest this but you have both beaten me to it.This ^^ weight on outside pedal as you lean into the corner ...
Not bad!This all sounds a bit sinister
This was something I had to unlearn when I started riding the Trike, with that you need all the weight on the inside to keep the wheel down.Left pedal up and push weight through right hand pedal - this will help.
Took some getting used to.
Like a roundabout in France ?Find somewhere quiet to practise.
Anyone else have issues with left hand cornering? Im fine on right handers, and I'm right handed, but left feels awful and i panic and wimp out!!
