Roseland triker
Cheese ..... It's all about the cheese
- By the sea
Wow .
Are you a roadie?
Are you a roadie?
Ah yes, it's the more expensive Alight 2 City that has hydraulic disc brakes. I probably wouldn't notice the difference on the local tow paths and the other shared use pathsSpec seems to be:
Tektro 172 Disc / Tektro MD-U510 and Shimano ST-EF41
So mechanical.
@Roseland triker poo poos @vickster Q, gets the answer 'think hydraulic' and then segues into:
Why grease the cables (new bike, new inners, new outers) - tell us more? Shimano recommends not doing so, I think. Old habits die hard, mind.
Loueese: "Ah, it's the more expensive Alight 2 City that has hydraulic disc brakes" (Tektro HD-R280)I just bought a Liv Alight 3 disc 2021
? I did buy a Liv Alight 3 Disc... It has the mechanical disc brakes. I'll be avoiding riding in the wet/mud as much as possible - assuming that makes some difference to the amount of maintenance required?Loueese: "Ah, it's the more expensive Alight 2 City that has hydraulic disc brakes" (Tektro HD-R280)
Don't come and spoil it! Let's pretend you actually bought a Liv Alight 3 disc.
The point @vickster (who is one of Cycle Chat Mechanics & Repairs ' leading ladies, and farther afield) was checking is that if you have hydraulics you need a book which covers those reasonably well because (my comment) that's the item that will likely give you most maintenance grief (reaches for helmet).
Thanks. Looks like he died quite young in 2013 and the most recent iteration of his book seems to have been in £2000. I'm not going to be a serious cyclist and I'll only be riding short distances and on the local tow paths and the like. So my needs are going to be fairly basic, I think.Richard Ballantine wrote the definitive book. I understand theres a modern version. Gives a good wider picture of the cycling world too, along with road craft etc. Presume it now delves into disc brakes. Others will be along to let us know…
I haven't seen a modern version but that was the book recommended by the trainer when I did my Velotech course. Some of the historic stuff at the start is very entertaining reading.Richard Ballantine wrote the definitive book. I understand theres a modern version. Gives a good wider picture of the cycling world too, along with road craft etc. Presume it now delves into disc brakes. Others will be along to let us know…
Mechanical discs are slightly easier to look after - they are just cable operated - so most likely better for you to learn to maintain them.Ah yes, it's the more expensive Alight 2 City that has hydraulic disc brakes. I probably wouldn't notice the difference on the local tow paths and the other shared use paths
Louise
On what do you base that assumption? Little tweaks maybe if they’re not busy.If it's a new bike, pretty sure you can take it to the bike shop how often you like for the first year or so and have it maintained/repaired for free.
Also, will come with a manual![]()
I've visited 4 bike shops with my partner in the last two weeks: Cycle Heaven, Evans Cycles, Liv Store, Giant Store. All offered free and unlimited repairs and adjustments of any kind for 12 months.On what do you base that assumption? Little tweaks maybe if they’re not busy.
Once you build a rapport with an LBS, they’ll offer help and advice but don’t expect it always to be FoC
Fair enough, good to hear given discounts on the bikes are pretty much non existent and prices through the roofI've visited 4 bike shops with my partner in the last two weeks: Cycle Heaven, Evans Cycles, Liv Store, Giant Store. All offered free and unlimited repairs and adjustments of any kind for 12 months.
