I don't have the scientific knowledge that other contributors to this thread clearly have, but I am interested to know what was going on with my bike (i.e why my chain started slipping) if the above assertions are true.
My (admittedly very limited) experience teaches me that a chain will start to slip as it becomes worn, and this problem will intensify the more worn the chain becomes. I have changed only one chain since starting road cycling last year. This was my experience -
Your inexperience with chains deceived you. As a chain wears, it starts to elongate and the pitch (distance from roller to roller) starts to increase. This places the chain out of sync with the sprocket and to make a long story short, the sprocket then wears with the chain. On a multi-sprocket cassette, the sprockets you favour wear more than the others. When you then fit a new chain, the new chain's proper pitch is out of sync with the worn sprockets and it skates (term for sliding over the top of the teeth without engaging) on those sprockets under high pressure like when pedaling hard up a hill. Soft pedaling doesn't produce skate. Skating happens even with perfectly indexed gears since it has nothing to do with not properly engaging laterally, but sliding over the top. If a derailer is not indexed properly, it causes another type of "slip" we call skipping. It literally skips between gears. Your description does not tell us which type of slipping happened.
I indexed my gears after the first couple of hundred miles of riding and then never needed to touch them again. I measured my chain wear periodically and found that my measuring tool indicated .75 wear after approx 2,100 miles of riding. Being even more naive then than I am now, I continued to ride my chain as it seemed to be performing as well as ever. Within another 100 miles, the chain had slipped 2 or 3 times on the cassette, something that had never happened previously. I rode the bike on 3 or 4 more long-ish rides after this whilst waiting for a new chain to arrive in the post, and on each of these rides my chain slipped regularly on each ride, to the point where I could not cycle uphill with any confidence. By this time I had done approx 2,400 miles in total and the chain was showing 1% wear.[/QUOTE]
Again, I cannot make a diagnosis because I am not sure what type of slipping happened and if you are not attuned to such things, you'll not be able to ID it retrospectively. I suspect it was a derailer/cable malfunction for whatever reason. Miss-shifts happen.
I fitted the new chain, indexed the gears and, to date, have not experienced the chain slipping again.
I realise now that I was silly to go on riding the previous chain to the point that I did. But what caused my chain to start slipping if not the chain wearing?
Thanks.
The fact that your chain tool said the chain was worn to 1% and that you managed to fit a new chain and not a new cassette, and then went on to ride without problems, tells me that the chain tool and/or your measuring technique is flawed. A chain that has elongated by 1% of its overall length (note that I don't say it has worn by 1% or somesuch) has already damaged one or more sprockets to the point where a new chain will not work with it. It will skate in the most worn sprockets when pedaling hard. You thus fitted a new chain to a unworn sprocket and therefore the tool is optimistic and designed to tell chains. Once a riders learns to distinguish between chain skate, chain skip and chain slip, remote diagnosing problems become easy. Otherwise it remains a guess.
