How to tackle Hills
BigonaBianchi
Yes I can, Yes I am, Yes I did...Repeat.
..you don't like big cakes?
john59
Wirral
I remember doing the 90km, four passes, Keswick sportive last year. My advice is to just take your time, there will always be people faster than you, and go at your own pace. But you do have to put some training in to make it, slightly, easier.
Shut Up Legs
Down Under Member
depends how fast you want to improve though
Just do more hills, or the same hill over and over, or ride into this wind we've been having of late.
My approach exactly. There's a popular cycling climb at the Dandenong Ranges, which conveniently enough is about 14km from where I live by road, so last year I rode up this hill on about 40 different occasions. Some days I took it easy, and on others I started the lap timer and really pushed myself, and my ascent time decreased by about 20%. The view's better than on a turbo trainer, too.
Nomadski
I Like Bikes
LBS, Usually
How did you do the fancypants elevation pic?
RussellZero
Wannabe Stravati
I'm not good at hills, but I have noticed how much difference loosing a few kgs makes. The other thing I'd suggest is measuring each run you do, use cyclemeter, strava or something similar, or just time your whole route, but for someone like me with a competitive nature it really spurs me on to compete against my previous best time.
philinmerthyr
My rear cassette is a 12-30. On the steeper climbs I find my cadence dropping to below 60 even in the lowest gear. I'm considering changing the rear cassette.
Would I be better changing my rear cassette so I can increase my cadence? I've seen 11-25 cassettes, would this make much difference? Is there a better ratio available? I need to use it with 105 shifters and mech.
Are there any other options. I plan to lose weight and get fitter as well as that will help more.
Nosaj
Rayleigh
The more teeth there are on the rear sprocket the easier the gear. Conversely the less teeth there are on the front the easier the gear. Dropping to a 25 would actually give you higher not lower gears assuming that you don't also change your cranks. The other thing to watch though is that as you increase teeth on the rear, so the chain size may have to increase otherwise you could end up with shifting issues. There are also compatability issues so you couldn't just throw on any high tooth rear cassette and expect everything to work.
Are you on a compact double 50/34 at the front Standard double something like 52/39 or a triple
I am not that Mechanically astute l but I am sure that if you can tell us what have up front and at the rear some others may be able to provide options/possibilities for combining MTB/touring cassettes with your current set up -
This may be better as a separate topic in the technical know how section of the forum
