coffeejo
Ælfrēd
- West Somerset
Make sure your push-off pedal is at the 10 or 11 clock position so you get the most benefit from that first push, and be ready with the other leg to carry it through. Having said that, I work on the theory that if my legs aren't able to get me restarted, they're probably not going to get me to the top, so I either take a longer break or start pushing until it levels out a bit.
I'm lucky with the quiet roads around here and if there's a car coming, happily take advantage of the longer break and wait til it has gone past. But the same rules about not riding in the gutter apply.
I've found the trick is to get into a low gear (I use the 9th lowest of my 24 gears) and just focus on pedalling steadily. Counting aloud and not looking up too much helps too
And your friend should wait for you at the top so you can regroup.
