GrasB
- Nr Cambridge
jimboalee, if I'm putting out 200w up hill & 200w down hill which requires the higher heart rate?
Fiona N said:... My favourite descent is from the petrol station above the Lluc monastry. Every cyclist who's been to Mallorca will know this fabulous descent to Pollenca![]()
GrasB said:jimboalee, if I'm putting out 200w up hill & 200w down hill which requires the higher heart rate?
Typically no more than 10% around here & due to the short nature of the 'hills', more pimples from the POV of someone in the lake district, very little in the way of technical descents. Quite often the ascent & descent will cover less than 1.5 miles, this means I can push very hard up the hill & still have enough go to continue pushing down the hill.jimboalee said:As for your question, they should, according to all the theory, require the same.
Riding down a hill, and you haven't said how steep, will produce a higher HR due to your brain's requirement to produce the necessary bravado to risk life riding a bike at 40 mph along a roadway with a 200 ft drop on one side.
There are bends in the roads descending some hills in the Peak District. If the roads were straight, I dare say I would spin-out in a straight line dash with 'normal' HR. But they are not straight and some require extreme concentration to keep the bike on the tarmac. In this 'real world' situation, HR will be above normal.![]()
GrasB said:Typically no more than 10% around here & due to the short nature of the 'hills', more pimples from the POV of someone in the lake district, very little in the way of technical descents. Quite often the ascent & descent will cover less than 1.5 miles, this means I can push very hard up the hill & still have enough go to continue pushing down the hill.
Now here's the interesting bit, on my Boardman hybrid, given my handle bar position that means I'm in a similar stance to what you'd expect on the hoods, I'll climb the steeper side of chapel hill (10% peak gradient) at no lower than 8mph on 42:27 that's just under 70ppm. From there as the climb transitions into the descent I'll go up the gears until I get to 42:16 at which point I'll hit the big ring & say in 54:16 all the way down, instantaneous maximum usually comes to around 42mph (or 155ppm give or take) at which point I'll gear up. Now doing this I'll always get maximum HR about 10s after I hit peak cadence.
jimboalee said:Let me throw this theory into the conversation.-
Phosphocreatine muscle contraction does not require the heart to beat faster.
Anaerobic states of exercise do not require the heart to pump blood as much as aerobic exercises.
Therefore, when climbing hills at lower cadence in the anaerobic condition, heart rate is lower than spinning furiously downhill in the aerobic state.
Discuss..
Bill Gates said:Are you 'aving a laugh?
jimboalee said:That finishes the discussion.
