Yes you can get up a 25% hill at a slower speed without having a 7W/kg power to weight ratio. You will need a 28T ring and a 36T sprocket to keep up a high enough cadence – about 40 – to keep momentum to climb at 2.5 mph.
Road race pros ( and most amateur sportive types ) don't pack a 21" gear for the occasional 25% gradient.
Unfortunately for the pros on the tour, some switchbacks in the mountains have 25% grades on the corners, and to get up them without stopping dead, they resort to their 7W/kg ability on a 46" gear.
Stopping dead half way up L'Alpe means losing the stage, and worse, losing valuable time because getting going again on a 7% grade is pretty hard.
If you ARE going to do this, you can't afford it to be broadcast on international television and "What happened next" on Friday night when Cav is on QOS. Especially if you ARE Cav…
On 39 x 25 it would be higher cadence and probably slightly faster due to this.
