trustysteed
shauncollier said:ok. so what is going on at exactly 21.1? there's a negative downhill bit, how do you read that?
you're going downhill!
shauncollier said:ahhhh, so it's not a downhill section with a little uppy bit? it's just that the gradient slackens off a bit? am i thinking right?
shauncollier said:so as a synopsis? everything above the line is up, everything below is down. if there is a straight line from +5% to -5% this means that the 5% hill slackens off down to the flat then goes downhill at a gradient of 5%. is this correct?
rh100 said:just switch the graph back to elevation, it will show the corresponding height you are at, showing where it flattens out.
ps......thats an amazing bit of countryside, I love that area![]()
