Dogtrousers
Lefty tighty. Get it righty.
Arguments not actions DT.![]()
I knew what you meant. I was just having a go at being mischevious and argumentative. I'm not very good at it to be honest. I'm too nice.
Perhaps I misunderstand the question but how will said cyclist wearing hi-viz help those road users, with no light source to see by, other than the moon and stars. Flouro doesn't in the dark and even reflectives are useless unless lit by a light source.Not from cars with lights, but what about other road users who don't have torches (pedestrains, other cyclists, horse riders, etc)?
I think you made a good case about the individual vs corporate meme thingy - hence I ignored it entirely!I knew what you meant. I was just having a go at being mischevious and argumentative. I'm not very good at it to be honest. I'm too nice.![]()
Brevity. I need to work on brevity.2897009 said:How would the HiViz work there?
Pedestrian crosses the road, street lights make cyclist with hi-viz easier to see. This is a good thing. Lights would be more important but hiviz will help the pedestrianPerhaps I misunderstand the question but how will said cyclist wearing hi-viz help those road users, with no light source to see by, other than the moon and stars. Flouro doesn't in the dark and even reflectives are useless unless lit by a light source.
And how do the listed road users see where they are going without constantly colliding with trees, signs, kerbs none of which use Hi-Viz, and, for that matter, each other?
It's that old intuition again. See @Adrian for details. This cyclist under streetlights without hi-viz, are they invisible to your pedestrian?Pedestrian crosses the road, street lights make cyclist with hi-viz easier to see. This is a good thing. Lights would be more important but hiviz will help the pedestrian
Is the cyclist blind? Isn't the onus on them to avoid the more vulnerable you?As for not colling with trees etc, they are static and certainly don't travel at 15+mph. If you don't see a tree until you are 10 feet away, you just walk aorud it. Don't see a cyclist trvelling at 15mph until 10 feet away, possible collision.
Where does all the reflected light from the streetlights go? Wouldn't some of it be reflected to the surrounding areas or does hi-viz not reflect at all?It's that old intuition again. See @Adrian for details. This cyclist under streetlights without hi-viz, are they invisible to your pedestrian?
The reflective strips on hi-viz reflect back to the source of the light with around a 20 degree spread (if my memory serves me right). People who are 90 degrees to the top of the lamp and the cyclist will not get any reflected light from the reflective material.Where does all the reflected light from the streetlights go? Wouldn't some of it be reflected to the surrounding areas or does hi-viz not reflect at all?
I agree, the cyclist should watch out. A pedestrian looks across the road, does not see a cyclist and steps out in front of them. Cyclist, with the best will in the world can do nothing to avoid collision.
But doesn't that assume it's hitting a perpendicular surface to the direction of light? Would it still be the same it the surface(jacket) is angled?The reflective strips on hi-viz reflect back to the source of the light with around a 20 degree spread (if my memory serves me right). People who are 90 degrees to the top of the lamp and the cyclist will not get any reflected light from the reflective material.
no. they use retroreflectors. They always send light back to the source.But doesn't that assume it's hitting a perpendicular surface to the direction of light? Would it still be the same it the surface(jacket) is angled?
... but as the drivers attention is focussed on the hi-viz wearing pedestrian he fails to observe the dark clothed mad axe man about to step off the pavement.Pedestrian crosses the road, street lights make cyclist with hi-viz easier to see. This is a good thing. Lights would be more important but hiviz will help the pedestrian.
ah, okno. they use retroreflectors. They always send light back to the source.
How does a light colour against a light background stand out?Just as running a car with dipped headlights enhances its visibilty to other road users, the wearing of light coloured or 'hi vis' clothing by pedestrians and cyclists, as recommended by the highway code, helps make them visible earlier than they would otherwise be to other road users. It is not a question of 'not seeing'.
I've started leaving the axe at home.... but as the drivers attention is focussed on the hi-viz wearing pedestrian he fails to observe the dark clothed mad axe man about to step off the pavement.
