tincaman
- Chudleigh, South Devon
You need to be going downhill to bed them in, at about 15mph drag one of the brakes for 5 seconds to heat it up and then come to a full stop with maximum pull. Repeat 5 times for each
Yes dont they just i also have the Carrera Vengeance took a bit of getting use to even in the wet they were just as good.And yet i have a Carrera Vengeance MTB with cable disc brakes that'll shoot me over the handlebars
After bedding in, brakes should be smokin' hot; too hot to touch. Some people recommend splashing water over to cool them down.You need to be going downhill to bed them in, at about 15mph drag one of the brakes for 5 seconds to heat it up and then come to a full stop with maximum pull. Repeat 5 times for each
Use the steepest hill you can find. Brake hard, but not so as you lockup and skid.
It may be that the OP has contaminated pads. I have never been able to remove oil from (resin) pads.
