Help! Tyre deflating after being pumped up.
compo
Harlow
If you want a cap have a snout round the airline station at a garage. there is usually a couple that drivers have forgotten to refit!
grumpyoldgit
Surrey
It would be handy if you could remove the valve core,clean it & put it back.For this you would need a valve tool,all good bike shops,& car accessory shops,as it is essentially the same as a car valve,keep these.Also if there is a car tyre shop nearby,it would take seconds to remove & refit.One last option,scout round some of the older cars parked up,it was not uncommon for a valve key to be incorperated into the cap.
dodd82
dodd82
Thanks for all of the advice - very much appreciated.
I'll give it a go and let you know how I get on!
dodd82
dodd82
No problem!
I need to learn these things anyway - all good experience.
Though someone might need to remind me of that when I am cursing the tyre later today.
compo
Harlow
Near Broxbourne, in Hertfordshire...
You have the LBS up on the High Road at Broxbourne, used to be Cycledaelia. I ride that way a lot, but unfortunately not today.
dodd82
dodd82
Thanks guys.
Bizarrely, I had a look at the valve and the middle part seemed to be stuck down. I shoved it with a paper clip and it's started working again!
