mickle
innit
- 53.933606, -1.076131
Right hand cup has a left hand thread....
If you've buggrered the splines you're at the hacksaw stage of the job. Make two or three cuts through the cup towards the bb shell. Cut as close as you dare to the shell - and then start in with a small cold chisel tapping the pieces away from the bb thread.
Good luck, it's a horrid job.
A month ago I wrote reams and reams on the engineering workshop practice of collapsing the threads (screw threads that is, not forum threads!) It can be done with a hacksaw blade as Mickle said, or a file as I described.
He said he'll use a heat gun and feels optimistic he can crack it.
This is great advice. I'll remember to look next time! Hopefully there won't be a next time, though! I intend loosening, greasing and re-tightening the bb on a very regular basis after this - should the bike frame pull through!
A friend of mine used to use a phrase I don't repeat all that often, but I'll make an exception here.
F*ck Me O'Reilly.
I've had one looked like that before, strange thing was although the BB felt a bit grindy it was running much better than might be expected. Those ball cages do tend to collapse, I rebuild them with loose balls.
Ended up replacing it with a sealed unit covered in plenty of copper-slip, so hopefully it should require little maintenance.
How should I grease - assuming my lbs is successful? Is copper-slip the way to go, or is there an incompatability with aluminium?
I suspect the cartridge in my bike wasn't greased in the factory. The bike isn't that old - just about 3 years - and I hope to get at least another 3 years out of it. Hope heating the bb bracket won't weaken the frame too much.
Copper-slip is better to use than grease. It's designed to be an anti-seize compound, rather than grease which is designed to be more of a lubricant. It's also harder to wash out..
Is it true that copperslip should never be used between two identical metals? In my case, that would be OK, as the frame is alu and the cartridge steel (I think!). I've read that copperslip applied to two identical metals can cold weld them together.
