Jimmy Doug
If you know what's good for you ...
Hi
Well, I know that this is about the most posted problem on bicycle mechanic forums, but I'm really at a loss. I've been trying to remove my bottom bracket and I think I've buggered everything up. The thing seems to have cold welded - a steel cartridge on an aluminium frame , probably not greased in the factory and now totally seized. I've tried leverage, hammering, and now I've stripped the splines trying to use a chisel, but all to no avail. Is drilling through the cartridge a possibility? Is so, how? I can't find anything that clearly explains this. I really hope someone can help - I'm so attached to this bike.
PS - I know the drive side is reverse threaded!
