- South Manchester
I know it's not clean but I don't think that's the issue, I'm sure this is where most of you will disagree!
If you really cannot sort it, then your LBS would be next stop not splurging £500.
I always use the high limit screw to align the derailluer jockey wheels under smallest cog first before clamping. Then turn barrel adjuster till they just start moving further inwards. Then turn back a tiny amount. Then check your 8 clicks and cog movements. If you get resistance for biggest cog then adjust low limit screw.
I think that's an unfair characterisation. Someone suggested I really should replace both outer cables, so I did that this morning. Someone else said the cable isn't clamped properly, so I checked, and so far as I can tell it is. I know a couple of you at least disagree but I've asked others with the diagram and photo and they think it looks fine. Plus like I say I've done it lots of times before.But the OP is going La-la-la to any suggestions, as he's not convinced. Bike shop it is.
According to the image it seems to me that the cable isn't clamped correctly into the "knurled" groove:
In my opinion hat roughly one millimetre deviation changes the ratio of the derailleur enough to cause shifting problems.
Hth,
E.
It should not. If you are doing yours that way I'm surprised that your wheels are even going roundThe 'tab' on the clamping washer should be over the cable.
OP's responses seem entirely reasonable to me. Pleased he didn't follow your clamping suggestion.But the OP is going La-la-la to any suggestions, as he's not convinced. Bike shop it is.
