Nigeyy
- Massachusetts, USA
Well, if it's a free bike....
Anyway, assuming it is a Raleigh with bonding, I had one too -used it extensively for mtbing, and then toured across Europe with it fully loaded. It ended up as my commuter at the end of its life -then the seat tube joint failed.
I noticed that when I was cycling I kept getting a noticeable "clunk" on the downstroke -at first I thought it was a bent crankarm hitting the chainstay... nope. Then I thought it was the bb, and replaced it.... nope, still there. I ended up suspecting the frame, and sure enough the seat tube was loose going into the bb area. To prevent anyone else riding the bike, I hacksawed it up (boy, did I feel like I was disposing of a dead body!) and was very surprized that the seat tube moved very freely away from the bb.
I do think Raleigh discontinued the bonded bikes for a reason, but on the positive side, my bike's demise could have been due to me using it considerably (thousands of miles, off road rigid mtbing, and fully loaded on road) and one could say it put up with loads of abuse.... I should also add it was a steel/alu bonded Technium frame, so you never know, it could have been different. And of course, many frames fail eventually anyway and you could possibly get some sort of warning signal when it might fail.
On the negative, frame failure is never nice, and I can't say I'd want to ride a Raleigh bonded frame in a hurry again. You also might get a sort of warning signal when it might fail
It's your choice!
It's your choice!
Whatever
Anyway its running part from brake cables and new blocks, needs a clean though...
http://www.cyclechat.net/threads/free-bike-build.125814/
