Crackle said:It'll be OK, there's good mechanics on the ride I here![]()
Forget mechanics! On this one there'll be a sag-wagon! I might risk setting off with only a couple of cable ties, a spirit of optimism, and a hip flask...
theclaud said:Keep telling yourself that as you embark upon your next lengthy disquisition on the virtues of butterfly bars...
Crankarm said:I have to say I think Ritchey stuff is cheap and nasty which is probably why it is on the Boardman bikes to keep costs down. I am looking at replacing the headset on my Spec Sirrus which I feel might be Ritchey as well with Hope or Cane Creak. The steering feels really heavy and sluggish and this is before I even put the bar bag and front panniers on.
GregCollins said:Light, strong, cheap. Pick any two.
I've broken an XT crank. So all Shimano is rubbish.
I seen a Hope hub sieze, so all Hope is gone.
I've had a Cane Creek seatpost snap when I wasn't caning it but it left me up the creek.
etc.,
etc..
components break. everything decays. every component on every mass produced bike is there to keep the cost down. Price point sensitivity, marketing and all that.
As for your sweeping and inaccurate generalisations, re Ritchey/Boardman products. Keep 'em coming, you are entitled to your thoughts and to let your irrational prejudices show I guess. Besides uninformed opinions like yours ensure there a few more Boardman's in the shops for people like me to buy when we want one.
Crankarm said:I would recommend getting the following tool from CRC to get the old cups out of the headtube. It's £16.99, so could be cheaper, but easily gets the cups out in seconds. Obviously you need a hammer or something similar to hit it with to knock the cups out.
http://www.chainreactioncycles.com/Models.aspx?ModelID=10223
GilesM said:That looks like quite a clever bit of kit, might have to buy myself one, thanks Crankarm.
Crankarm said:Not my experience Grumpy - you're welcome to Ritchey components.
Crankarm said:You're welcome. I wouldn't anticipate it being a regular use item, but one of those tools one would use periodically, without which one would be well and truly stuck or reliant on an LBS. I think if one has a few bikes, it pays for itself after a couple of headset changes. The use of long screw drivers as an alternative simply doesn't work and risks damaging the inside surface of the headtube.
GilesM said:I expect you just need to get the bolts on the stem torqued up correctly, and use some thread lock on them. Although it is okay to do without a torque wrench, many people suffer from fear of crushing the carbon syndrome, a torque wrench does remove this problem.
theclaud said:Thanks Giles. The LBS torqued them to the correct setting when replacing my bearings - it's only because I've had to retighten them on the road that it worries me. I could get some thread-lock though - I confess I never thought of that...
MacB said:I'd be concerned if they've come loose having been tightened to the correct setting. Worth popping back and getting them re-done with threadlock and seeing how that goes. I've mused over buying a torque wrench but I don't have the carbon considerations so have relied on guesswork. But this was on LBS advice as mine is a pretty old fashioned establishment.
I'm assuming you've factored in little allen keys and girly hands![]()
