Hi to everyone,
I had a new bike delivered yesterday that just needed the handlebars and seat putting on... easy right?
Well I have managed to screw it up somehow, first off put them on wrong way round, sorted that tightened everything up and noticed the headset, steering column was loose.
Tried tightening the top cap after loosening the stem bolts but it was already tight and would not go anymore.
I took the top cap nut out and removed the spacers to see what was happening.
I then took off the stuff above the bearing cup not noting down the order, as you do, it only has three anyway.
From what I can make out, (be easier if you looked at the pics) the part that sits on top of the bearings does not fit in, or should it even fit in? The whole steering tube is loose because there is nothing centering it.
So I am completely stumped now because I have now taken the fork out thinking I could then get the part to sit in the bearing cup, but I don't even know if it should fit in the cup, there is a rubber ring with four cut outs adjacent to each other Which I don't know where it's supposed to go.
Just to add the underside of the
piece above the bearings is completely flat on the underside, not conical
This is an electric bike by the way, not as if that matters but instructions are useless and would not be able to contact the manufacturer because I don't know who it is.
Any help would be greatly appreciated, on the order to put it back together and how to center the tube.
Thanks.
Thanks.
