Johnsco
Old Fettler
- Leeds, West Yorkshire
I've recently brought my old Carlton back from the dead after some 35 years of neglect.
During this time, a friend (???) borrowed and abused the bike - So badly that it wouldn't go at all when I got it back.
I've a number of questions.
Forgive me if some of them appear elementary.
I'm a reasonably competent engineer, but I've not that much experience on bicycle engineering.
First question:
While riding, I notice a "clacking" sound from the head tube.
To check it out, I pulled on the front brake, and then rocked the bike backwards and forwards against the brake.
I could feel play between the large nut [labelled "B"] and the head tube.
I loosened off the smaller nut [labelled "A"], which I guess locks the larger nut.
I then found that the larger nut was only finger-tight and I could rotate it.
I tightened it about one full turn.
Any more than this appears to stiffen up the steering.
This appears to have eliminated the free-play.
I then tightened down the smaller nut around the stem tube, making sure that the little bracket supporting the brake cable was central.
Now, when I ride over bumps, the "clacking" sound has gone.
Question ... Have I done the right thing ?
Could I have done any damage ?
Is lubrication or replacement of this bearing ever required ?
Is there a "How to" that relates to overhaul of this part ?
Any help or guidance would be most welcome.
Thanks
(Other questions may follow soon !!)
First question:
Thanks
