migrantwing
I use the Sheldon Brown method to make sure I get the crossings in the correct location with respect to the valve, @migrantwing will probably find this a useful resource.
http://www.sheldonbrown.com/wheelbuild.html#key
Thanks for the advice and link, @YellowTim
That's how I started.... with an old wheel You'll find it's easier with a new wheel though.
One step at a time and keep everything under control. You can always go back to square one if you made a mistake. If you are getting frustrated then walk away and come back later.
Good luck
Thanks, @Spoked Wheels.
My best wheels are relatively new but have bladed spokes and less of them. My practice wheel and hub are 36h, so I'm hoping the more the merrier as I've been told that the more spokes there are, the easier a wheel is to true regards fine adjustments over a smaller area, as opposed to less adjustment over more of an area with less spokes. I guess you know what I mean
Good luck and Take note of your mistakes and when there logged in your head it then becomes easy....well, easier.....
Will do. Cheers, @Tojo! Haha!
You do realise I'm holding ALL of the above responsible when this goes wrong
