Cannondale Lady
- Sunderland
I will show Hubby this post!
Just as everyone else said...gets easier with practise. I would spend an invaluable 30 mins having a go at getting the tyre on and off so you know what to do. Also a few pearls people have shared with me or I've learned on the way:
1. Always check the inside of the tyre for sharps before replacing the tube (otherwise won't be long until you're doing it again!)
2. Spend a minute double checking that the tube isn't caught between the tyre and rim before inflating
3. Check the tyre wall isn't split (went through both my tubes and a friend's before we realised what the problem was!)
At least, are you getting faster at fixing them?![]()
Very sensible suggestion! A year or so ago I came upon a rider I knew, many miles from home, who had used up his 2 spare tubes, both puncturing after a few miles. He had no puncture repair kit. I helped him remove the tyre and it was only after very close exanmination, flexing the tyre as we went, that we discovered a tiny piece of glass - which I removed with the fine point tweezers I carry. I 'lent' him a glueless patch, fixed one of the tubes and he went on his way. It is really crucial to find out what caused the puncture, and whether it is still there, ready to make a hole in your new tube! I never leave home without my tweezersGreat idea. I suggested tweezers to hubby for his repair kit for getting thorns or glass out there but he looked at me like I was an alien!
there may be a slow puncture so I'm watching it.
brilliant, the op was worried about a flat, now they are worried their bike is about to spontaneously combust!!This shouldn't happen. I'd be concerned that your rim is bent.
35,000 and quite a few punctures: I've never had a tyre come off a rim. In fact, I've never heard of it happening unless the wheel was damaged.
I read somewhere that many tyres are under a lot of pressure these days and the gooey stuff comes out so fast it doesn't get time to mend and just makes a nice mess of everything.I'm guessing that the puncture sealing stuff ( slime and the likes) isn't any good as no one is mentioning it?
I used some when I had a puncture in my rear wheel a few years back, and I fitted a tube with it already in to my front, and have had no problems.
It works fine to hybrid/roadster pressures (80psi max) but I did once redecorate King Street with slimy foam after pumping up a tyre with a hole that was too big for the slime to seal properlyI read somewhere that many tyres are under a lot of pressure these days and the gooey stuff comes out so fast it doesn't get time to mend and just makes a nice mess of everything.![]()
