Tojo
- Newcastle-upon-Tyne
No one else has mentioned so I thought I'd just make it clear that Shimano 11 speed rear derailleurs have a different pull ratio to earlier derailleurs, so you can't use an 11 speed derailleur with a 9 or 10 speed lever and vice versa. (however there may be cable routings or devices that do make this possible but I've not come across them yet.)
According to Leonard Zinn (on Velonews website) all the 11 speed cassettes are interchangeable, and chainsets/front derailleurs will almost always work to a greater or lesser degree.
Yes,11sp has a shorter pull ratio on the cable each time you index because it has a narrower chain and the cassette spacing is also narrower, now though with 11sp it is cross compatible to an extent as in chains so therefore the sprockets have the same pitch, but I'm not quite sure about indexing as earlier Campag had different spacing on their cassettes, so therefore their shifters will take up a different amount of cable each shift. I haven't got enough money to experiment with Campag chainset and front DR and say Shimano rear set up..funds or just a build up of bits and bobs I come across may allow me in future...!
I think the cable routeing device you mention was like a pulley system that you fitted to to a Shimano RD to be able to run a campag cassette (or vice versa.. sorry cant remember) but that was pre 11sp, Also type this into google......shimergo.....!. Enjoy....Oh I just do love mechanical things.
