Ming the Merciless
There is no mercy
- Inside my skull
A 90s mtn bike with tyres for semi dry trails if you want to go cheap.
I am informed they are about to become fashionable in Bristol !A 90s mtn bike with tyres for semi dry trails if you want to go cheap.
For £300 notes I built up an old Dawes hybrid for a chum in a fix. 700 wheels with good tyres. Then comfortable flat bars and a good saddle plus a very light weight rack as he needed that. He is so pleased and it does everything he needs well , so when he saw a 2k gravel bike he said `What more has he got than I have ?' Well there was a not a lot in it, bar a great deal of money and a flash paint job. Do your own !
Look at Merlin they have a gravel bike in XS for £600. With Claris. I'm sure that would be alright for you unless your wanting to do a lot of muddy trails, then I'd say get a hardtail. Merlin Malt G2 Claris Gravel Bike - 2021 | Merlin Cycles
Yeah, but finiding a a nice frameset from the 90s in a good state might not be that easySeriously a 90s rigid mtn bike is perfect for the gravel bike use case.
32mm tyres are fine for canal paths, I and many others have ridden them on 23s, you just have to slow down, which you should anyhow on shared paths. 32mm are fatter than any of my current bikesRight. I spen over an hours. And decided I want this cannondale only because it’s a baragin and I’m missing a point here and 32mm tires won’t be good, and going over a budget…
This Merlin looks perfect! I will give them a call first thing tommorow morning thank You!
But if want to ride on proper gravelly farm roads and the like then yes, a gravel bike would make sense
I’m not sure about a bike in prawn peach myself though!
Can you actually get the Specialized? My LBS says there are virtually no non electric Spcializeds anywhere.
You can always add secondary crosslever brakes on the handlebars to a drop bar bike (as long as it doesn’t have Hydraulic brakes, the Merlin doesn’t). I have on all my road bikes, asI prefer the position especially in
traffic. Example in photo.
how long are your long rides? Plenty of people do 50+ miles on flat bars
I’ve never had an issue with crosslevers nor the two friends I ride with. With smaller hands, we all find them safer for braking and they are the default for us so no issue in an e. Even with shims, more small hand friendly Sram hoods it can be hard to get enough purchase and power. And I’m not a petite woman like the OP.@ms.hyde whichever bike you chose may I add a word of caution re using cross levers on drop bars, I do appreciate it's each to their own. Something like 20 years ago I was knocked off my bike resulting in a broken hand and damage to the tendon which runs from the base of the thumb across the palm. I wasn't able to use the brakes on my drops for six months. My LBS fitted cross levers which worked well and I quickly got used to them. The difficulty came when we removed the levers. I had learned to reach for these brakes and it took me a considerable time to unlearn using them.
In my view having both cross and standard levers on a drop bar has the potential to confuse the rider, especially in an emergency stop. Reaction time is important and the brain needs to know what to do automatically rather than deciding which levers to grab!!
I would agree with you re 32mm tyres, I ride 35mm on my gravel bike, though I regularly ride with a friend who comfortably uses 28s. The towpaths I know round Manchester are mainly wide and well surfaced and OK for 28s but there are cobbled sections, for example, which I think would be tricky.
Up here the towpaths are generally narrower, can be muddy and I know three people who've fallen in......all riding unsuitable 28mm tyres.
On my 35s I feel confident, I'm sure 32s would be the same but I'd be very wary of 28mm on many of our local towpaths.
Exactly, and I was adding my experience as a word of caution.As a bloke ymmv, I was just giving the OP a suggestion.
I'd echo this from my GF's experience of cross tops on her gravel bike and switching between that and a road bike with no cross tops, no issues. I also fitted microshift R10 short reach brifters to her gravel bike, which help for small hands.I’ve never had an issue with crosslevers nor the two friends I ride with. With smaller hands, we all find them safer for braking and they are the default for us so no issue in an e. Even with shims, more small hand friendly Sram hoods it can be hard to get enough purchase and power. And I’m not a petite woman like the OP.
None of the manufacturers have yet bothered to design mainstream brifters for smaller hands. I think Microshift may offer something for kids but they’re not standard on adult models.
