My arms have only a slight bend in them I find I have to straighten my back out at the bottom also you see I've read and been told that when the heel is on the pedal you still need a very slight bend I'm so lost with it all il put a shorter stem on tonight I'm taking the MTb until I get the bike back hopefully later when a mate of mine returns it after checking it over again plus the roads are getting badly mudded uptry some common pointers for bike setup and take it from there. Set the seat height so your heel just falls on the pedal. Next set the seat position, with a pedal in the 3'oclock position drop a plumb line from your knee. (I used a piece of string with a spanner on the end). the line should fall somewhere in conjunction with the pedal spindle. Move the seat back/forward to get the required result.
With the seat position set, lean onto the bars like you would when cycling. Are your arms outstretched or do they have a bend in them, do you feel like you are having to reach out, or do you feel bunched up ? Do you feel like you are leaning over too much ? stems will flip. that is, when you turn them upside down the angle will raise them slightly. For me this made a huge difference coming from a hybrid and not used to leaning over. If you feel like you are being stretched after flipping. try a shorter stem.
Next check your cleats if you use them, are they lined up with your foot, or are you twisting on the pedal to feel comfortable. I had mine set in the middle but taking a shoe size up this made them too far forward for me. I dropped them back towards the heel by 10mm and it feels much better.
Once you set these, mark where everything is. then adjust 1 thing at a time until it feels right for you.
ThanksMy arms have only a slight bend in them I find I have to straighten my back out at the bottom also you see I've read and been told that when the heel is on the pedal you still need a very slight bend I'm so lost with it all il put a shorter stem on tonight I'm taking the MTb until I get the bike back hopefully later when a mate of mine returns it after checking it over again plus the roads are getting badly mudded up
No looked either very nearly straight or a slight bendIs your leg straight when on the pedal at the bottom of the revolution and is there some bend in your arms when holding the hoods or are your elbows locked?
  Even if you are posting on a phonei agreeYou should be able to go miles in comfort if the bike is set up properly, if it is wrong, you will be lucky to get to the end of the road.
And sort out the reach. The knee will be due to saddle height, back the reachI did not try the bike with a shorter stem, I will take it home with me tonight. I've come in on the mountain bike today.
I must admit my knee is better my back still ached, I guess I will have to get the core up to scratch.
I a
i agree
