Mr Pig
- North Lanarkshire
fossyant said:Anything 'technical' i.e. computer side of the car - it's off to a garage.
I bought an old laptop, diagnostic software and a cable that plugs into the car's ECU. It's pretty cool actually :0) You can look at everything; fuelling level, MAF output, revs, oil temp, TPS output, in total about twenty parameters, on the computer whilst the engine is running. You can set it recording and go for a drive so that you can look at it later. You can reset the ECU and tell it to change to change things, even switch cilinders off. Unfortunatly you can't remap the ECU with it, it's a learning ECU but it's not programable, but it's still a very useful bit of kit.
