I think i found potential problem with the SyncDrive motor? I can't eliminate chain contact with the derailleur when in 50/11 ish.
Their seems to be what i would say is excessive endfloat with the motor crankshaft. I've noticed that when your right foot is on the power stroke the shaft moves out (slightly) causing the derailleur contact that's not apparent when Not under power of the motor (on the stand).
It's even noticeable in the video that
@Foghat linked here at around the 17.50 mark showing the noise on the right foot power stroke.
I would say i have at least 1/64 or more play when pushing the crank in an out........ Any comments about this? Is this normal do you know?
Mine has a small amount of play too.  And another unridden brand new Road E+ 1 I've seen.  So it looks to be 'normal'.
My front derailleur started rubbing the chain quite badly when in the 50t chainring, after a couple of hundred miles, and had rubbed less noisily in 50-11 right from the start - after riding a while, the bedding-in of the gear cables had created some slack that needed taking up with the inline front gear cable adjuster, and the rear derailleur adjuster.
Increasing the front gear cable tension with the inline adjuster did eliminate the rubbing in the 50t ring, but only after I had also altered the throw range of the derailleur with the high limit screw.....and it left it rubbing unavoidably in the 34t instead.
The inline adjusters fitted by Giant are not particularly well designed and are quite hard work to unscrew enough to get enough tension into the cable - I had to adjust it all the way down with the cable disconnected, then pull the cable by hand+pliers as hard as physically possible to get as much pre-tension into it before clamping with the cable bolt, and then screw the adjuster right out to get the required high tension to stop the rubbing in the 50t.
The outer limit screw needed to be let out a bit more so that the derailleur could travel far enough out to not rub with the highest achievable cable tension.  The throw range of the RS685/105-5800 lever/derailleur system is a bit limited and not ideal for use with the pulley that inverts the cable direction to the front derailleur.  The convoluted route around the pulley, and the associated friction, introduces cable action resistance to the derailleur's downshift, and because the high limit has to be adjusted further out, the downshift to the first trim point is compromised, and it tends to struggle if there is any power going through the chain.  So downshifts under a degree of power, that 5800 and Ultegra 6800 derailleurs can cope with easily without penalty when not combined with an inverting pulley, are now more difficult, and often require also shifting again, to the lowest trim point, to get the chain to change rings.  And rubbing will probably be switched to the 34t and the lowest gears.
Obviously this is not ideal, but I'm pretty sure the pulley, and its effect on cable resistance to downshifting,  is a key element of the difficult-to-escape rubbing problem.  In practice, I very rarely need to change down to the 34t ring due to the considerable extra power the bike gives me on hills, so it doesn't bother me too much - not rubbing in the 50t is far more important as I spend 100% of my commute in it!  As a perfectionist in the mechanics of my various bikes though, and never suffering this on any others, it does irritate slightly.
I've also bought some better quality Shimano inline adjusters that look like they'll be easier to adjust, and will install them when the gear cable outers need changing.
I have another bike with a Dura-Ace 9000 gear set, also with an inverting pulley (different pulley design to the Giant's), and had none of the problems discussed above, so it seems to be peculiar to the system Giant has adopted on the Road E+.
In short, you should be able to adjust the rubbing in the 50t out on your Road E+, but downshifting to the 34t may well be slightly compromised by the high cable tension needed, and the chain will probably rub in the 34t and lowest gears instead (but this isn't as noisy or annoying as in the 50t and highest gears).
