OK, so I solved the padded short slippage dilemma, I’ve taken to wearing them under my cycling trousers/tights and not on top. Oh and “Site Pin” I took a leaf from your book and went without underwear….”No more chafing!!” Yeah
Moving on to a different topic, I put in 240 miles last week commuting to work for four days in a row. On the last day my bike developed a clicking noise coming from what seemed to be the crank or motor area (like an aluminium frame clicking on steel bolts). I stopped several times to tighten what I could around the motor and frame but to no avail. By the time I got home some 30 miles later the clicking had developed into creaking on every revolution of the crank. The noise stopped when I turned the motor off but oddly the noise also stopped when I put the motor onto power mode and asserted lots of leg power. All this seemed to come about after I oiled my chain with 3 in 1 oil (I was in a rush to get to work!). The oil then proceeded to deposit itself all over the bike!
So at the weekend I methodically removed the plastic panels that shroud the motor module checking the 3 bolts holding the motor, they were all tight. Never the less I dropped the motor from the frame and could see no evidence that the motor had been moving on its mounts. So I cleaned everything up, including the chain and cassette (which were covered in 3 in1 oil) then dry lubricated the chain, derailleurs and cassette, and put everything back together. I then took the bike out for a test run and no more clicking from the crank.
“The good old take it apart, find nothing wrong and put it back together method”
On a separate note and I don’t know if this is related to the issue that “Giantbadge” had but every time I hit a bump in the road my fork stem clicks or cracks. I’ve had this a few time on my Giant Deft 3 (which is aluminium).
Is this something that is inherent with aluminium frames?
And does anyone else suffer this?
