Yellow Saddle
- Loch side.
Okay, so I couldn't find a chain tool so wasn't able to take the chain off unfortunately. I took a few pictures last night, although I don't know if they're any help, with the chain being on and also bad light + camera flash. Anyway, to took photos of the derailleur from the top whilst on the little ring, on the big ring, and also a side view to show the clearance between the cage and the big ring. It's hard to see from the photos, but there didn't seem to me to be a problem with alignment.
http://imgur.com/nAzbkfz
http://imgur.com/VNE5GLQ
http://imgur.com/eoCOU7w
Without knowing what gear the bike was in and hence not knowing the chain line, I think the derailer needs to be repositioned so that it is parallel with the chainrings. In the one photo it seems a bit tail-out. The two blades should be in line with the chainrings because the pushing bulge is about 1/3 from the front and it seems like yours is making contact in the tail-end of the derailer. Can you conform that? The height seems fine and the limit screw seems fine.
