Gravity Aided
- Land of Lincoln
I've three 26 inch cycles that have not been terminated, as of yet.
I'm referring to New production.....2014 was difficult to buy a good 26".... 2015 virtually impossible!worlds biggest makers have ceased production.I've three 26 inch cycles that have not been terminated, as of yet.
Matters if you liked the 26" wheel bikes and would like a new model using the latest kit/frame technology, they simply don't exist!This matters why?
Tony.
I think the 26" can have it's place,It was OK for 30 years!shorter small framed riders on technical rides,requiring fast acceleration etc....my point is this the market has taken the choice away,rightly or wrongly its happened!Is it such a hardship to get a bike that doesn't have 26" wheels then?
I tend to change gear, one at a time whenever i feel my legs are either spinning or pushing too much. If I feel i'm spinning (not doing enough work), I change to a higher gear... if i feel I'm pushing (doing too much work), I change to lower gear. It means changing gear a lot, but it works for me.
I think the easiest thing to do is know your local routes . When you are coming up to a harder part you know when to change from the big ring to the small ring at the front before you get there . If you find how to match that on the rear ( it will be the same gear as you where already in according to your legs ) then you only have to click down or up one cog as the ride goes . Once it gets easier then do the reverse and go back to the big ring on the front .
