There's bugger all difference to a beginner.
I've Sora, 105, ultegra on three different bikes. All good.
The OP wants to know if to a beginner there is much difference between sora VS tiagra VS 105 VS ultegra.bollox. or if so that is not down to just Sora vs 105 that is probably down to the rest of the bike or lack of maintenance
When you stop being a beginner, then you start noticing the difference immediately.
Oof, running two road bikes with Shimano 600 (Tricolour Ultegra) and 7400 Dura Ace. Both have been fantastic. Only had the groupsets over 30 years, terrible value.![]()
The best you can do. If you get the chance. Is to get a test ride on bikes with the different group sets to see what you think. As others have said I wouldn’t get hung up on it as a deciding factor between bikes. Check gear range and see how the bikes actually feel when you ride them.
I get just as slick a change from the bottom of the range Tourney on my mountain bike as I get from the 105 on my road bike.So would I really, as a beginner, notice any difference between a bike equipped with a Sora set as opposed to a bike equipped with a 105 set? Or between a Tiagra or Ultegra or 105 vs Ultegra etc.....
Would I notice a smoother or faster/slicker gear change or not?
Should I not get hung up on this or should I aim for a particular set up as a minimum requirement and why?
Gears simply move the chain from one place to another and that is the basic requirement for even the very cheapest set on the planet.As mentioned 105 was always the decent benchmark but as technology and shifting capacity has trickled down I think Tiagra is more than enough. Agree the bit about Sora to 105 being 1000 times better is Bollox per upthread. Maybe the Sora was badly indexed, who knows. Only really big noticable leap is from conventional to electronic imho. As regards alternative shifter brands, you know the old saying and I happen to agree with it after owning all 3 for thousands of miles…
Campag looks pretty, SRAM is light, Shimano works!![]()
will skip the toast…Only the clicky shifters for the mechanically incompetent, isn't it?No but presumably you are aware that there are differences in the number of gears certain shifters can handle? Perhaps some find more choice desirable but who knows. Now I’m off to make myself a nice cup of teawill skip the toast…
