raleighnut
- One of the 'Elite'
Big fan of 105 here, right balance of quality, long life and weight
Amen! Shimano haven't made good groupsets since 600 Arabesque and Tricolor. The current range is just a choice of how polished you want a turd.SRAM Rival ftw
(I really don't like Shimano brifters with the wobbly brake lever and oversized hoods)
Don't get sucked into bike groupset snobbery. Leave it to the bike snobs with more money than sense.
It depends which 5x2/6x2. As I wrote, Arabesque (1978) and Tricolor (1988, Ultegra) were OK and Shimano has been outclassed by its Rivals forever since.So I would be a fan of buy Claris and accept that it may not be what you want in a year or two's time, but it is way better that the 5x2/6x2 sold in the late 1970s.
Apex and force are just as good*, I'd put the SRAM lineup closer together spec wise than ShimanoSRAM Rival ftw
What's your budget, new vs. used? What else are you looking for in the bike...racy, more endurance/relaxed, need for mudguards and rack, frameset material hankering etc...the groupset is probably among the last things to consider depending on budget.
Have you actually ridden any modern roadbikes?
Force is above Rival, never used,Apex and force are just as good*, I'd put the SRAM lineup closer together spec wise than Shimano
*Except when I forget I'm on a 1x gravel bike and try to shift
What’s funny?
Explaining SRAM to meWhat’s funny?
Force is above Rival in the sram hierarchy (Ultegra equivalent), I’ve never used it though so cannot comment on how it compares to Rival (105 equivalent)
I wasn’tExplaining SRAM to me![]()
Shimano 105 is called "The groupset of the people". It is widely considered to be the best value groupset. Cheaper groupsets will wear out faster, are less reliable, and weigh more. More expensive groupsets weigh less, but don't really last much longer and are not much more reliable. As a beginner with an intent to ride a lot for the next five years, 105 sits at the sweet spot. To give you an idea of what the extra money will buy you, I am currently replacing my Campy Chorus bottom bracket after 50,000 miles.Hi, in my tentative search for my first road bike I have seen various bikes with various gears and there is obviously a lot of choice but with a lot of price differences?
For example, it seems that Shimano 'Claris' is the most basic, and 'Sora' is also fairly low down compared to say the 105 set? Then there is Tiagra although I think Ultegra is above that? All very confusing for a beginner.
So would I really, as a beginner, notice any difference between a bike equipped with a Sora set as opposed to a bike equipped with a 105 set? Or between a Tiagra or Ultegra or 105 vs Ultegra etc.....
Would I notice a smoother or faster/slicker gear change or not?
Should I not get hung up on this or should I aim for a particular set up as a minimum requirement and why?
