MacB
- Farnborough, Hampshire
Well the height and the diameter of the new chainrings will be different, I think it's 2mm per tooth but can't remember if that's radius or diameter, if the latter then it would be 10mm lower and the former 5mm lower...for the front derailleur. Lowering the FD to match the new big ring should take care of the small ring automatically. I've messed about with a Tiagra FD a few years ago, took off a 52/42/30 triple and put on 48/36/22 and it worked fine after a bit of height and angle adjustment. But no guarantees the version you have will be as accomodating, but a new FD isn't expensive if needed.
As for cranks and BB, is this an external BB or an older style?
