Nigelnaturist
- Pontefract
Just check the B.C.D. I tried that on my prowheel chainset and it has a really odd B.C.D. on the 30th ring I also read that the shimano triples 30th can only be replaced with 30th rings though not sure. I replaced the whole chainset with a touring one till I got fitter from June 2013 till about May this year, I had down as low as a 26x28 or 1:0.9 or 24.4" though I could change the rear on mine to a 26/32 instead of the current 25/28 to give much the same I can lug a 15Kg bike up a 15% hill with the 30x28 so a carbon should be a breeze, if I did that I would hardly need the 30th and a compact 34 would be almost redundant, as around here I would never drop off the 40th ring as 40x32 is 1:1.22 or 32" or so, and I hardly ever go that low.Slowmotion, perhaps I should try that with my B Twin Triban 3. Find a 8 speed one with 28 tooth and see.
