lulubel
- Malaga, Spain
As there is no thumb lever, it must be tiagra, but will check later.
It's Tiagra. You can just see the "GRA" on the top in the photo on your first post.
My OH had exactly the same happen to her a couple of weeks ago. To get the broken off bit out of the lever, flick the small, black lever on the back of the brake lever (the one you use to change up) until it stops clicking. Then pull the brake lever, and you should see the broken off bit inside.
You might be able to get away with just changing the inner - my OH did, and her bike is the same age as yours and has had a lot of use. Before she ran the new inner through, she gave the old inner a good coating of chain lube and ran it backwards and forwards through the outer several times. Quite a lot of debris came out, and it's presumably well lubricated now as well.
Her gears are now working smoothly.
