Marie Attoinette Fan
Did you shift down your shifters (the same direction as you'd do to top gear, to return the unit to the zero tension position). I've never used Tiagra but with 105 you just press the trigger at the rear of the brake several times until it stops clicking.Thanks. Point taken about the cable route being different on my bike compared to the bike in the vid.
I pressed the right brake and I cant see the barrel-end of the cable. It shouldbe visible because I can see it on the other brake (maybe it pinged off onto the floor somewhere? is that likely?).
When i press the brake, a screwed-down small panel is exposed. Do i need to undo remove this panel to gain access to the barrel-end (if its still there and not on the floor somewhere)?
There's no screw with 105, the cable end is exposed when you shift down.
