Ajax Bay
- East Devon
This 'fraying inside the STI' risk elevated when Shimano introduced the 'under bar(tape)' route for the gear cables, so very much this century. The main issue is the cable deterioration occurs out of sight and is a pita to extract once it breaks (likely in the middle of a ride with no warning).I've not had a gear cable break ever as far as I can remember and I had the first version of Shimano STI with my dura ace back in the early 90s. Maybe even the late 80s. I'd only be changing mine if I was replacing the group set. I don't change gear cables when I change bar tape either - am I a bad mechanic?
Replacing gear cables on a schedule (time or distance) makes sense (and would entitle you to a 'good mechanic' badge).
I've only once had a gear cable break (and I coulda shoulda changed the cable before the ride as pre-travel I had seen a filament break at the FD clamp end). Was 70km into a 600. Used limit screw to fix the FD on the middle ring. Rode on to Rhayader (clivepowellbikes - great(known) bike shop) and replaced cable (and a coffee) and on north (17 minutes).
