I am having the same problem - cadence is working but speed is erratic at best. I have a Garmin Edge 800 w/Speed and Cadence Sensor. Sample data here:
http://connect.garmin.com/modern/activity/607482853
About a month ago, the speed stopped reading accurately. At first, my speed reading cut out for a few seconds, then picked up again. Eventually it stopped working all together. After trying the following troubleshooting steps, I still have the problem:
- replaced the battery in the speed/cadence sensor (battery was fine, I was getting the red light flash as pedal went past censor)
- Adjusted space between crank arm censor and speed/cadence censor (it was rubbing a bit)
- Reset Garmin Edge 800 (backed up, wiped out and restored my Edge 800 this AM)
The problem persists.
Quick Questions:
- Does the crank arm sensor have a battery in it?
- If I am getting a red light, it should be functioning properly, right?
- Has anyone had this problem and fixed it without having to replace the hardware?
I believe I am off to Garmin Support too. May have to rely on the GPS alone for speed for a while?
