T.M.H.N.E.T
- Northern Ireland
If it's not obvious, you're wasting your time arguing.
We used to all ride with triple front chainsets and the only time I ever remember anyone ever having issues was the result of a bent outer ring.
Doubles and singles on mountain bikes only came about because of marketing crap from shimano, sram etc. Not because anyone needed them. And sure as s*** not because of any performance benefits.
My issue with 1x is length. I tend to ride to where im riding so need a.decent long gear to crack along in the roads toget from a to b.
Yup. And you could save a lot of that weight with a down-tube shift lever. (simpler and more reliable than briftersAh but most of those things had performance benefits of some kind. Reliability, weight, ease of use.
There's none of that with going backwards from a triple chainset to a double or single.
Weight savings maybe but we're talking mere grams there.
Yup. And you could save a lot of that weight with a down-tube shift lever. (simpler and more reliable than brifters)
Having built up three MTBs over the last few years from a bare frame, I spent a fair bit of time deciding what drive train to use.
My thoughts were:
3x
A traditional 42/32/24 triple with 8 speed 11-32 cassette gives the same range as the expensive 1x option for around 10% of the price (plus in my experience the parts last longer too).
Operation is honestly no more complex/hassle than a 1x drive train.
So I'm running 3x8 on all of my MTBs and wouldn't go back to 1x given the choice.
no i didn't but that would add expense wouldn't it? doubling the price of the cassette?Did you know that you can use sprockets from a 9sp block in an 8sp one? e.g. put your 36T into the space where your 34T now is.
They're not actually the right thickness, but with just 1 sprocket the difference is utterly irrelevant!
It can be a time-consuming process - depending on model/manufacturer but if it gives you the perfect setup, that can be worthwhile. And some folks love fettling![]()
