I have been getting chain rub on my Triban 3 (stock, unmodified) when in smallest front chain ring + biggest rear sprocket on the inside of the front derailleur (i.e. lowest gear)
I attempted to adjust the limit screws on the front derailleur to compensate but they only adjust so far. Why?
Because, as the OP pointed out, the spring for the front derailleur spring rests on the frame and prevents the full range of motion inwards.
Therefore chain rub seems inevitable when in the lowest gear (necessary for West Yorkshire hills!). This is an unmodified Triban as supplied by Decathlon although I have done plenty of miles on it.
Other than buying a new front derailleur that fits better the only thing I can think to do is to shim the chain rings outwards slightly to adjust the chain line at the front? Another 0.5mm ~ 1.0mm ought to be enough.
Sound reasonable or should I be looking elsewhere?
Cheers.
p.s. I haven't measured the chain line yet.
Hi Data,
I know exactly what you mean.
The main d/r return spring sits uncomfortably close the frame when you are in the granny ring........you will notice that the designers thought this through somewhat and have incorporated a depression in the tube to accommodate it.
When I fettled my Triban front mech I was conscious of this tight clearance - BUT - I have to say, I have managed to set it so that the chain runs without scraping the mech in the lowest gears and the spring doesn't collide withe frame. Whether it is because I have just managed, through trial and error, to set the angle and height of the mech at its optimum, I'm not sure........but the mech spring clears the frame by a gnats whisker (set by the limit screw) and has not altered its position or needed resetting ever since. Clearly - it CAN be done if you persist. I have shimano wheels too and didn't experience any need to change the front set up.
The rear was a different matter, however..........good luck.,,,and I HTH?
best
w
