Tigerbiten
If the derailleur moves easily when you move the lever but doesn't stay to where it's moved to then it sounds like the ratchet in the shifter that keeps the derailleur on the big ring isn't catching.
I'd take the cable off the derailleur, pull it tight by hand and try various shifts both up and down.
Can you feel the ratchet catch when you shift up and let go when you shift down ??
If you can feel it working then it comes down to cable adjustment.
If not then you may have a dead shifter ......
Luck .............
Luck .............
