jefmcg
I just replaced my front derailleur cable. The derailleur is tiagra, the shifter is 105 (I replaced the original shifters, which were tiagra). There doesn't seem to be a barrel adjuster or anything in the path. As far as I can tell, this means you have to undo bolt holding the cable, and readjust it then tighten it again to get it in the right position. Is this right, or am I missing something?
I had real trouble moving between the chainrings before I replaced the cable. Now it's moving fine, but when it's on the big chainring, it's over a bit too far, and rubs on the derailleur. I'm reluctant to undo the bolt and try again, as it's much better than it was - it's just not quite right. I'm I missing something that should allow me to tweak the "nearly right" cable, or do I have to start from scratch each time?
Already so used to the the noise of the chain rubbing, that when @vickster said "oh, it's your bike that's squeaking" it took me a few seconds of concentration to hear the noise.
