T4tomo
Turns out I had crank puller tool already, just that I had forgotten about it.
However, when driving it down, it's not budging. I was using a lot of force, you can see the bare metal where it's defacing, and the crank arm wouldn't budge. Am I in trouble here? I have included the RH crank in the second image so you can compare.
View: https://imgur.com/a/J3zGmpI
is the end of your puller tool small enough to fit?? i dont think it is.
i think you have a
ccp 44 copy tool
you need a ccp 22 equivalent for sq taper
